gusto77
Feb 22, 2019Aspirant
Firmware upgrade failed
I tried to update to the latest firmware tonight and halfway through the download it quit and showed an error icon. Now I can't do anything with the router. It won't connect to 192.168.1.1 (wired or ...
- Feb 23, 2019
Hooray for your help. There were a few glitches in the instructions but this is the one that worked: https://kb.netgear.com/000059633 . The one thing that was off was the link to download the Tftpd64 software was dead but I found it at https://bitbucket.org/phjounin/tftpd64.
I thank you all so much. It would have taken another 10 days to order a new router from Alaska.
michaelkenward
Feb 23, 2019Guru - Experienced User
- gusto77Feb 23, 2019Aspirant
- michaelkenwardFeb 23, 2019Guru - Experienced User
For future reference, if you have Windows 10 there is no need to any download. Just enable the built-in tftp client. That's what Netgear now recommends.
