Windy_9
Sep 02, 2021Aspirant
Firmware upgrade for GS105
I have an old 5-port GS105 switch which I would like to upgrade. What's the procedure?
- Sep 02, 2021
Windy_9 wrote:
Thanks for your prompt reply;
What model of Netgear switch would you recommend to extend my home network?Any unmanaged switch will do
Sep 02, 2021Guru - Experienced User
the gs105 is a simple unmanaged switch.
There isn't any firmware to update
Windy_9
- microchip8Sep 02, 2021Master
- plemansSep 02, 2021Guru - Experienced User
You put "extend your home network".
Are you looking for a new switch? going with a mesh system?
What exatly are you looking at doing?
- Windy_9Sep 02, 2021AspirantBeen having problems with my GS105 which connects to my printer, cctv, tv etc so since I can't upgrade I want to find the most suitable switch to replace it.
What exact issues are you having? Switches are pretty robust and rare to fail.
And they usually either work or don't. Not much of the sometimes work/sometimes not
