tdavison1962
Sep 30, 2022Aspirant
Firmware upgrade getting stuck on language file - Nighthawk R7900P
I am attempting to upgrade my Nighthawk firmware and getting stuck on the message: Upgrading language file. It will not get past this message and upgrade the firmware. Firmware Version V1.4.1...
- Oct 09, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Sep 30, 2022Guru - Experienced User
Are you using the routers auto update feature or manually applying the FW update file?
