tdavison1962
Sep 30, 2022Aspirant
Firmware upgrade getting stuck on language file - Nighthawk R7900P
I am attempting to upgrade my Nighthawk firmware and getting stuck on the message: Upgrading language file. It will not get past this message and upgrade the firmware. Firmware Version V1.4.1...
- Oct 09, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Oct 01, 2022Guru - Experienced User
You can manually update.
https://www.netgear.com/support/product/R7900P.aspx#download
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
- tdavison1962Oct 09, 2022Aspirant
Thank you, that worked great
- FURRYe38Oct 09, 2022Guru - Experienced User
Enjoy. 📡
