rlmarker
Jan 25, 2019Aspirant
Firmware Upgrade LED blinking amber
Firmware 1.0.4.28 instructions Important Note reads as shown below. Note 1 says to power cycle the router with a blinking amber LED. Note 2 says the LED should be blinking amber during firmware upd...
- Jan 25, 2019
The power LED blinks during update. After the update is finished, the router restarts by itself. After this is done and everything is up and running, the power LED should be solid white or blinking white. If this is not the case, you *may* need a reset
microchip8
Jan 25, 2019Master
rlmarker
Thank you, microchip8!
I think I get it now. If the progress bar does not display correctly and the LED doesn't turn white, then one must wait a reasonable time (10 minutes?) before doing a reset.
Richard
