dlafeve
May 23, 2018Follower
Firmware upgrade on R6900 Cannot login to router, Windows 10 will not pass through the signon.
Router is working, have been experiencing low connection speeds with my Samsung TV and Ipad less than 1Mbps, yet on my computer Spectrum speed check is about 60+Mbps. Spectrum Support suggested my r...
- Jun 04, 2018
Hi dlafeve,
If you are unable to access the router's page as it is not accepting the default login and not able to recover the password then the next step to do it to factory reset the router. Here's a reference link of how to do it:
If you cannot login to your router
Once you have successfully logged into the router's page then you can go ahead and check router's firmware version. Here's a reference link:
How do I check for new firmware and update my Nighthawk router?
Blanca
Community Team
Blanca_O
Jun 04, 2018NETGEAR Employee Retired
Hi dlafeve,
Blanca
Community Team
- Blanca_OJun 10, 2018NETGEAR Employee Retired
Hi dlafeve,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Blanca
Community Team
