eson's avatar
eson
Firmware upgrade to V1.0.7.6 breaks wifi security settings
WiFi password settings are gone after firmware upgrade to V1.0.7.6. Factory reset did not help. No password setting and can't change channel setting. I also tried reflashing firmware.
  • ElaineM's avatar
    ElaineM
    Jan 10, 2017
    Welcome to the community, eson
    Thank you for bringing this to our attention. I will go ahead and forward this to our engineering department.
