GKACK
Dec 20, 2016Tutor
Firmware Upgrade Using Remote Management
I need to do a firmware upgrade on my R7000 router and can only do remotely since the router is in a home that is only used seasonally. I have remote access and when I search for a firmware upgrade ...
- Dec 21, 2016
GKACK wrote:Not sure if this changes anything but when I search for a firmware update on the router it comes back and says "No new firmware version available"
The fix for the R7900 is still in beta, so it will not show up in the web interface.
As FURRYNUTZ says, there will be a beta version on the support pages for that device. Keep your eye on that, and the security advisory, and it should tell you when the firmware goes "factory". Then you may be able to do a remote update using the web interface.
Security Advisory for VU 582384, PSV-2016-0245 | Answer | NETGEAR Support
GKACK
Dec 21, 2016Tutor
Ok, thanks to everyone who responded. It turns out that I was a little confused about router models since I have 3 Netgear routers between homes and work. The router in the remote location is actually a R7900 running firmware version V1.0.1.4_10.0.12
At this time there are only security cameras, wifi connected speakers and a VOIP phone using the wifi. Unless there is a high risk of something, I can easily wait until I am there or I see that a firmware upgrade is available in the router's interface.
Thanks to everyone.
michaelkenward
Dec 21, 2016Guru - Experienced User
