rsarvie
Apr 04, 2018Initiate
Firmware V1.0.1.44_10.0.44 tanked my 2.4GHZ Speed
Recently updated my R6700 to Firmware V1.0.1.44_10.0.44. First had to reset both modem and router multiple times as I had the "Your computer appears to be correctly configured, but the device or reso...
- May 27, 2018
Hi All,
Please try the new firmware.
https://kb.netgear.com/000058220/R6700-Firmware-Version-1-0-1-46
bugmenot2
Apr 19, 2018Apprentice
Thank you!!!
It also dropped all of my 2.4GHZ devices. A reboot of the router would show them for a few seconds under the 'connected devices' but a single refresh of that and they were gone. I tried every which way, including enabling a brand new 2.4 ghz guest network, nothing would ever connect (I have five devices - thermostat, wifi plugs, lights, etc.) All of them fell off with the upgrade, so it's definitely not a device issue. Reverting as you suggested fixed everything - all five devices came right back on without me needing to do anything to those devices.
JamesGL
May 27, 2018NETGEAR Employee Retired
Hi All,
- rsarvieJun 22, 2018Initiate
Thank you for the reply James. After about 2 weeks now having done the update in your link I’ve had no issues with speed, or access, as previously mentioned in my original post. All devices have been logged on and using WiFi on my 6700 now for about 2 weeks successfully. All speeds are running in the 50’s or higher on 60 Mbps service using Speedtest.net testing all devices, where they have unobstructed WIFI, and some areas seems possibly better than was previously, in the weaker fringe areas, howeve that’s anecdotal. I have enabled the auto update option now in the settings for continued firmware updates as well now that I’m satisfied with the latest update. Thank you for update and the reply.
Ryan
- Blanca_OJun 25, 2018NETGEAR Employee Retired
Hi rsarvie,
Thank you for your feedback. Glad that it's working now.
Blanca
Community Team
