SWE_Tommy's avatar
SWE_Tommy
Follower
Oct 14, 2021
Firmware V1.0.4.76_10.1.82
Hi. After update firmware to ver. V1.0.4.76_10.1.82 some problem have came.
I turn off 2,4Ghz and 5,0Ghz number 1, 10 oclock pm every evning, but the router even stop 5,0Ghz number 2.
You can see the wireless 5,0Ghz nr 2, but you can not login.
If I login to the router and do a manual reset of the wireless it works.
/ Tommy
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Two immediate options:
    • factory reset the router and see if that fixes the problem
    • revert to the firmware that worked as expected
