A0157202
Sep 12, 2023Aspirant
firmware V1.4.4.94_1.3.56 VPN stops working
After we upgraded to this latest firmware our OpenVPN connections stop working after about 24 hours of uptime. It happens on all Windows clients. OpenVPN works fine for about 24 hours then it stops...
A0157202
OpenVPN Windows config files were regenerated. Note that this works for about 24 hours. Then ceases.
2.5.8 but there are probably other versions.
Windows 10 Pro & 11 Pro. All current on Windows updates.
Only 1 session per client ever. From client to Netgear. Most of the time only 1 person is using this. But when it fails for her it fails for everyone.
Kitsap
Sep 12, 2023Master
A0157202 wrote:OpenVPN Windows config files were regenerated. Note that this works for about 24 hours. Then ceases.
Have you configured and are you using a Dynamic Domain Name Server service?
One thing that happens on a 24 hour cycle is the expiration of DHCP leases for IP addresses. Are your client machines configured for a fixed IP? Are you client machines set for a reserved IP address from your router configuration?
- A0157202Sep 13, 2023Aspirant
We are not uisng DDNS as we have a static WAN IP address.
No address reservations are for the VPN users. Only for MAC/IP address reservation for an MFP.
- KitsapSep 13, 2023Master
The most recent (August 15, 2023) update to the Windows client application is version 2.6.6. You might give that a try. I updated several machines without issue and continued with the previous configuration files.
Who is your ISP? Mine is going through a lot of local changes and upgrades.
Are you using your ISP default DNS? In your router, have your configured any of the public DNS?
Does your ISP support IPv6 and do you have it enabled in your router configuration?
Logix is out ISP in the Dallas TX USA area. They seem to be stable and we are on a 1GB Internet fiber connection. 1GB is WAY more than we need/use.
DNS isn't the ISP's. We are using 1.1.1.1
Yes they support IPv6, but it has been disabled on WAN & LAN.
