elijr78
Aug 16, 2021Aspirant
Firmware Version 1.3.3.140 Issues
Since updating the firmware to Version 1.3.3.140 for my AC2300 Night Hawk R7000P model, every other day or so I need to reboot the router. During those times, I wake up to find out all of my wired (Ehthernet) connected devices don't have internet access. After I reboot the router, internet connection comes back. Because if this, I rolled back the firmware to the previous R7000P-V1.3.2.134_10.1.66 version, which I never have any issues with in the past, and it resolved that issue so far. I updated it because it indicated the newest vesion has some security fixes. For anyone with the same model I have (Night Hawk AC2300 R7000P), have you experienced this issue as well? Please advise. Thanks.
theres been quite a few posts on the forums about the latest round of updates causing issues.
I'd stay on the version you're on until a new one comes out.
- klt212Tutor
Hi, yes I have. I am planning to roll back to my previous version as you did this afternoon. Looking for the instructions to do so. I believe all I have to do is download the file from Netgear and install.
- elijr78Aspirant
Yes, just retrieve firmware V1.3.2.134_10.1.66 and complete the roll back process. I'm hoping Netgear will find the issue with that newer version and resolve it. Then I will update to the lastest.
In case you can't find it, I provided you the link.
https://kb.netgear.com/000062806/R7000P-Firmware-Version-1-3-2-134?language=en_US
Thanks
