HAAVV33
Aug 09, 2021Follower
firmwarw update
hi netgear please we need un last update virsion of netgear ( N300 model DGN2200V4 router ) i try to find it on the dowloade section but you didnt upload it
hope u upload it ASAP
SINCERELY LAY
What version are you looking for? that last I'm showing is from October 2020.
https://www.netgear.com/support/product/DGN2200v4.aspx
that devices was originally made10 years ago. I'm impressed its getting updates at all
Do you have a problem that needs fixing?
That's an ADSL2+ Modem Router that dates back to 2011. (Does anyone still use ADSL2+?) As plemans says, there is new firmware from September 2020. You are unlikely to get much more recent than that.
We are talking about a basic router with ancient specifications. According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware. This may not matter to you, but be warned that it will hobble you if you ever sign up for faster Internet. It also slows down whatever is going on in your local network. Newer devices support 1000BASE-TX.
The wifi is also not be up to much. It does not even support 5 GHz wifi.
Nothing wrong with it being old, just don't expect too much.
