T_C_
May 14, 2024Aspirant
Fix or Workaround for R6700v3 DHCP management interface bug?
Does there exist a fix or workaround for the bug in the DHCP management interface that prevents altering the address range on an R6700v3? We have an R6700v3 in service, that is configured to dyna...
T_C_
May 16, 2024Aspirant
No, that range does not work either. No changes can be made to the configuration -- DHCP cannot even be disabled, as I described.
So, basically, this router is electronic waste if the configuration needs to be changed, because Netgear wrote egregious bugs and never bothered to fix them. Well done Netgear.
May 16, 2024Guru - Experienced User
If you disconnect the router from any WAN connections and LAN devices accept for the one wired PC, factory reset and setup from scratch, by pass the checking for internet services, manually setup, get to the home screen, can you then change the IP address range at all?
