KB2MXV
Jul 22, 2022Initiate
**FIXED** Unable to join 2.4GHz Network
I have been pulling my hair out trying to figure out why I'm unable to join my 2.4GHz network. I have a NETGEAR R7450 with FW 1.2.0.92 Simply removing the period "." in the SSID name fixed my...
Jul 22, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
microchip8
Jul 23, 2022Master
You should also get rid of spaces. Officially, only dashes are allowed (-)
- FURRYe38Jul 23, 2022Guru - Experienced User
I've never seen a issue with spaces...i use one. Been using one for same SSID name for years. Special Characters can be problematic.
