Moriaki
Dec 07, 2019Aspirant
Fixed wifi ip has no internet connection
Trying to set a fixed ip on my wifi connection (tried it on several apple devices) It connects to the router, but I get no internet connection I can see the device in my list of attached devices (w...
- Dec 28, 2019
Hi all.I finally got it to work.
Some more testing showed that I had no DNS translation.(on wireless devices with set IP-adresses)
Wired devices and dhcp provided devices were just fine.
Reset the router, re-entered DNS server(s) on devices and it works.
It puzzles me that it was no issue for DHCP provided adresses. A parculiarity on IOS?
In any case, problem solved and thank you for the support.
schumaku
Dec 13, 2019Guru - Experienced User
Double checked that this device represented by that static IP isn't blocked to access the Internet on the R9000? This could have happened long before....
The R9000 does allow any device connected, or is there some additional security prohibiting the Internet access again?
Moriaki
Dec 28, 2019Aspirant
Hi all.
