mwassy888
Nov 05, 2020Aspirant
fixing a device to 2.4 vs 5 using smart connect X6 R8000 & X6 EX8000
Hello, I have an X6 R8000 V1.0.4.62_10.1.74 & EX 8000 V1.0.1.224. The ex8000 is configured as an extended with smart connect and one wifi name. I originally had smart connect and one wifi n...
microchip8
Nov 05, 2020Master
Not with Smart Connect enabled. SC on NG routers is suboptimal and often doesn't work as intended due to bugs. If you want to pin devices to a specific band, use the traditional method and not SC
mwassy888
Nov 06, 2020Aspirant
Understood thank you for the feedback.
