BellamyDustin
Feb 03, 2023Tutor
flashed DD-WRT onto my R7000 router.
Hi guys, I'm new here and to DD-WRT. Recently, I flashed DD-WRT onto my R7000 router. I selected the 'dd-wrt.K3_R7000.chk' file on that list. All was working fine until this morning when my power...
michaelkenward
Feb 03, 2023Guru - Experienced User
BellamyDustin wrote:
It boots up, cycles through lights but then the power light stays amber ....
On stock firmware that is a sign that your router has corrupt firmware.
I hope that the people behind DD-WRT firmware have "get me out of here" instructions – perhaps you checked them before you went down that road – but as FURRYe38 says there's nothing that anyone from Netgear can do to help you with third-party firmware.
- BellamyDustinFeb 04, 2023Tutor
michaelkenward wrote:
BellamyDustin wrote:It boots up, cycles through lights but then the power light stays amber ....
Sure thank you sir
