DeniseK
May 03, 2021Aspirant
Flashing orange light on Netgear79 Nighthawk R7000
The display on my router has a white flashing power light a white flashing light next to it and then another white light and then over the number one on the numerical display 1234 the number one is a ...
- May 04, 2021
What modem do you have?
What firmware is on the router?
What connectivity issues are you having? we need a better description to help you. not just "connectivity issues"
If you go to the manual, it goes over what each led is and whats its flashing/color means.
I'd advise looking at that so you can give a better description of the led's as well.
May 04, 2021Guru - Experienced User
- DeniseKMay 04, 2021Aspirant
thank you. problem solved. some ignorance on my part.
