dralign
Jul 19, 2021Follower
Flickering amber light on ethernet connection on R7000P
Hello, I decided to connect my hight end tv by ethernet rather than wifi. It works fine but the ethernet port light for the device on the router flickers on and off. Also the 2 white lights to the ri...
microchip8
Jul 19, 2021Master
Flickering is just minor random network chatter. As for amber light, your TV comes with a network chip at 100 Mbps (instead of 1 Gbps). In this case, the router uses Amber to report the speed. Nothing to worry about.
