dralign
Jul 19, 2021Follower
Flickering amber light on ethernet connection on R7000P
Hello, I decided to connect my hight end tv by ethernet rather than wifi. It works fine but the ethernet port light for the device on the router flickers on and off. Also the 2 white lights to the ri...
michaelkenward
Jul 20, 2021Guru - Experienced User
Flickering lights usually mean traffic. This is all explained in the manual,
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the bits in the manual Table 1. LED descriptions and Troubleshoot With the LEDs.
