yukonuck
Dec 17, 2016Aspirant
For R8000 router, what version of Firmware is required to resolve issue VU#582384?
I received a notice 2016/12/16 from Netgear to update the Firmware on my router to address the VU#582384 command line vulnerability, but the info and links in that email refer to what appears to be a...
- Dec 17, 2016
The new firmware is v1.0.3.26, while the old one is 1.0.3.4, not .40, so the fixed firmware is infact newer.
I updated my router a little earlier today using the auto update feature and had no issues with the upgrade so far.
perk82
Thank you for asking. I have the exact same question and do not want to download something that isn't needed. I use the NetGear Genie and it says my 1.0.3.4 version is the most current/ up to date. Do I leave it along or 'go back' to this 1.0.3.26 Thank you to anyone who can give us a CONCRETE answer.
- EluderDec 17, 2016Star
- mdgm-ntgrDec 18, 2016NETGEAR Employee Retired
1.0.3.26 is the latest firmware.
Please continue the discussion here: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Two-leading-Netgear-routers-are-vulnerable-to-a-severe-security/td-p/1185124
