bathepa
Feb 10, 2021Aspirant
force TV to 2.4ghz (R7800 Nighthawk)
I have one TV that sometimes has trouble getting a good signal. It'd be impractible to wire it with an ethernet cable. Everything that is connected wirelessly appears to connect to the R7800 with 5gh...
Feb 10, 2021Guru - Experienced User
You an always disable smart connect and set different name for the wireless networks. Then you can choose which devices to connect to.
- bathepaFeb 10, 2021Aspirant
Thank you. I had to use the app on my phone. I turned off Smart Connect. it looks like everything is on 2.4ghz except what is connected by ethernet. I'll see how this goes from here. Thanks for your help.
- plemansFeb 10, 2021Guru - Experienced User
When you turn off smart connect, the name you were using before is the name ths 2.4ghz ssid uses. If you want devices to go back to 5ghz without having to change them all, change the ssid name of the 2.4ghz to something different and put the 5ghz with the same ssid.
