Zerowrx
Aug 23, 2021Tutor
Forced to change Admin password.
First I'll apologize for what is most likely a topic that has already been covered but there are too many password posts to wade through to find an answer. That being said this morning internet conn...
michaelkenward
Aug 24, 2021Guru - Experienced User
Zerowrx wrote:
The internet dropped out and Netgear Genie popped up on the TV and forced the password reset then asked for the serial #.
What is this "Netgear genie".
A genie could be one of several things, the browser interface, a Windows or Mac program for a PC, or a mobile Android/iThing app. Netgear labels them all as genies. Which are you using?
I have never seen any genie that has anything to do with a TV.
I'm afraid I find it difficult to follow what you are doing. Saying "not doing anything out of ordinary usage" is of little diagnostic value. We need to know what you were doing, not what you weren't doing.
You now tell us you were using a FireStick, so we are a bit less in the dark. (I use one all the time, so have some understanding of how they work.) But we don't know much more than that.
In my case, I have used a Firestick in wired LAN and wifi modes. It connects to the Internet through a Netgear router.
I have never seen any hint of a genie, or any other Netgear program, on the device that connects to the Firestick.
Zerowrx
Aug 24, 2021Tutor
Thank You for your time,
I don't know how to explain it any better then I have. ?? I was watching the Firestick and using the laptop checking emails / social media, ordinary usage the Internet dropped out and the Genie popped up requiring password reset & serial #. Both the Firestick and laptop are connected via wifi. The genie that popped up was "THE" Netgear Genie used on the initial set up and monitoring of the modem, the genie was not opened or accessed at the time of the issue. (see attached)
4K Firestick
Asus laptop
Samsung smart TV
- michaelkenwardAug 24, 2021Guru - Experienced User
We suddenly have a laptop in the picture. Yet more key information that you haven't mentioned before.
So, this "genie" pops up on the laptop?
You previously said "Netgear Genie popped up on the TV". No mention of any laptop.
I still don't know what genie you are seeing.
Is it on the laptop? Is it a browser? Is it an app on a mobile device? (I have used all of those.)
Believe me, I am not being picky. It is simply impossible to diagnose what might be happening with so much missing detail.
I have also used Samsung "smart" devices. There is no Netgear genie for those that I have ever found.
- ZerowrxAug 24, 2021Tutor
In all fairness the laptop was stated in my first reply second sentence. "I was using my Fire Stick to stream and the laptop." The Genie popped up first on the TV through the Firestick when the Internet dropped and then the laptop when I woke it up.
- PreciousKaosFeb 10, 2022AspirantWow. You say you're not being picky, michaelkenward, and that may be, but youre definitely being unnecessarily difficult and arrogant also. There are a number of details sufficient enough to progress which you can glean from the OP without harassing them about unrelated semantics. And if you have to ask what a Genie is, you shouldn't be attempting to give advice on a Netgear forum. Just sayin. Be helpful or don't.
- michaelkenwardFeb 10, 2022Guru - Experienced User
Welcome to a six-month old discussion.
