Texan007
Mar 18, 2021Tutor
Frequent No Internet
Having frequent no internet. Meaning internet gets disconnected at the router mr60 model. I have to restart multiple times (from routerlogin.net) and it starts working. Anyone Having similar problem?
1 Reply
We'd need more info to help out.
1. What modem/gateway is the mr60 connected to?
2. When it goes down, do all devices drop? Have you checked if your wired devices drop as well?
3. what firmware is the mr60 on?
4. It doesn't fix on the first reboot?
5. When it goes down, are you still able to access the router?
6. You said it gets disconnected. Do devices get disconnected from the wifi or do they say "connected, no internet".
