bumrocks's avatar
bumrocks
Follower
Dec 07, 2019
From R6020 to R6080 - No Change in Performance
Quick note, I'm not sure whether this is a Nighthawk router. The Nighthawk app is referenced numerous times on the box though. I recently upgraded my modem from the R6020 to the R6080 due to the fa...
  • plemans's avatar
    Dec 08, 2019
    Both of those devices are fast ethernet devices. What that means is their ethernet speeds are only 10/100 and not gigabit. So you'll max out hardwired speeds at around 90-94mbps on either router. so if you have 200mbps internet speeds, they'll never hit that.
    If you're testing over wireless 2.4ghz 50 mbps is pretty good. Potentially your 5ghz should get you more than the 50mbps but that'd take a little more fine tuning and troubleshooting. If you're planning on keeping 200 mbps speeds and want to actually hit that, I'd recommend upgrading to an actual gigabit router if you're going to have 200mbps service.
    if you're happy with just getting 90mbps, then we can troubleshoot your speeds. If you want full speeds, upgrade to a router capable of handling them.
