lesliebutler
Oct 16, 2021Aspirant
Frontier FIOS Compatibility
I am switching from Spectrum as the ISP to Frontier FIOS. The line comes in to the house over a fiber optic cable to a connection box on the outside. From the connection box it is connected to my c...
lesliebutler
Re Question 2: I have the AC1900 Smart WiFi Router Model R7000 Serial number 5L62067BA1366. What is the correct configuration steps if Frontier gets the ARRIS to see the internet?
lesliebutler
Re: Question 2 answer do you have a C7000 or a R7000? those are 2 different models. One can easily be made to work with it versus the other takes different steps.
I have both the R7000 and C7000 version 2. Which is easier to configure to work with the ARRIS NVG468M/Q?
- FURRYe38Oct 16, 2021Guru - Experienced User
the R7000 how ever if you have a router and wifi in front of the R7000, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/24104/How-do-I-change-my-Nighthawk-router-to-AP-mode-after-I-ve-already-run-setup
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode- lesliebutlerOct 16, 2021Aspirant
The installer is due in a 1/4 hour. I will use your suggestions to work with him and Frontier ISP
If your going to use the R series router in AP mode, not much to have the ISP tech check for. Just ensure there services and hardward are to spec and in good working order.
