Deathsightgq
Feb 23, 2016Aspirant
FTP unable to connect from outside
So I set everything up have a dynamic dns and i can access the ftp internally but cannot access the ftp from the outside any suggestion. heres a little I have verizon wireless modem and my router is ...
- Feb 23, 2016You didn't specify which router you have, but since you are posting in the Nighthawk forum, I'm going assume that's what you have.
If you look on page 89 of the R7000 manual, you'll see that there are two FTP settings. One to enable local access and one to enable Internet access. You need to enable the latter.
http://www.downloads.netgear.com/files/GDC/R7000/R7000_UM_21Dec2015.pdf
Deathsightgq
Yes If I enabled it like I said works internal but not from the outside same thing if I pick the HTTP as well it works internally but not from the outside
Deathsightgq
Not sure what happened but now it works
