StrossBoss's avatar
StrossBoss
Follower
May 14, 2020
Galaxy S20 R8000 wifi issues
Hey all, I have been having connectivity issues with pretty much any android phone that tries to connect to the network. First it was both my girlfriend's and my Pixel 2XL. Recently we switched to th...
  • microchip8's avatar
    May 14, 2020
    Smart Connect on NG routers is pretty much sub-par. It is not that "smart" at all and can cause various issues. Do a test by disabling it and see if the issue goes away. Then you'll know it's Smart Connect causing it or not.
