Baxterdad
Feb 23, 2023Guide
Generac loses wifi connection R7800
Wondering if anyone else has experienced issues with WIFI connection to a home Generac unit. The generator uses 2.4g to communicate to its' Mobile link app. The connection gets established but is lo...
- Mar 20, 2023
Finally resolved. The WIFI module on the Generac was the source of the problem. Service Tech swapped it out and it has remained connected.
A final thanks to everyone who offered suggestions and guidance. I learned a lot about the router in the process and I'm more confident with it's settings and performance.
The NETGEAR community is an amazing resource! Participants can be proud of their work and the knowledge they share freely.
Feb 24, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Does this device have a ethernet port by chance?
- BaxterdadFeb 24, 2023Guide
Thanks for your help.
Firmware version is V1.0.2.92
The modem is not ISP device. It is my personal device. NETGEAR CM600
The LAN cable is CAT5E. I will try a CAT6 as you suggest.
Unsure if the generator has a ethernet port but I was considering a hardwire connection rather than WIFI if it is available just to put this issue to rest.
- labattFeb 24, 2023Mentor
Same issue with TP-Link Aps.
