Baxterdad's avatar
Feb 23, 2023
Generac loses wifi connection R7800
Wondering if anyone else has experienced issues with WIFI connection to a home Generac unit. The generator uses 2.4g to communicate to its' Mobile link app.  The connection gets established but is lo...
  • Baxterdad's avatar
    Mar 20, 2023
    Finally resolved. The WIFI module on the Generac was the source of the problem. Service Tech swapped it out and it has remained connected.
    A final thanks to everyone who offered suggestions and guidance. I learned a lot about the router in the process and I'm more confident with it's settings and performance.
    The NETGEAR community is an amazing resource!  Participants can be proud of their work and the knowledge they share freely.
