Enterprise77
Apr 02, 2022Aspirant
Generic streaming device
Generic streaming device showing up in my list of devices. I block the device, then it unblocks itself! I deleted it, came back again even though I marked do not add devices automatically! I'm at a...
- Apr 03, 2022
Disable the iPhones WiFI Privacy Address feature. This is the feature that causes this. This is a Apple feature. Not needed when Apple devices are at home.
Enterprise77 wrote:
Yes, my son's Iphone.....different IP/MAC address...
Enterprise77
Apr 03, 2022Aspirant
Apr 03, 2022Guru - Experienced User
- Enterprise77Apr 03, 2022AspirantThanks, will try after work. Will advise
- Enterprise77Apr 03, 2022AspirantSuccess! That worked! I was wrong, no a security issue as thought. I can keep my router a little while longer!
- michaelkenwardApr 04, 2022Guru - Experienced User
Enterprise77 wrote:
Success! That worked! I was wrong, no a security issue as thought. I can keep my router a little while longer!Thanks for reporting back. Very useful.
Yet another one to add to the list of unexplained things that Apple and Samsung, and probably others, do to baffle us.
