wyogal
Dec 29, 2020Aspirant
Get message ENETO: looking up IP address from DHCP
I am just changeing my old Netgear for a new onr. Everthing on my personal side works great now. I also had my work computer hooked up to it and it worked fine before I switched it out. Now when I...
antinode
Dec 29, 2020Guru
> I am just changeing my old Netgear for a new onr. [...]
Thanks for the detailed descriptions of both those devices.
> [...] Now when I try to log in on the work computer it says ENETO:
> lOOKING UP IP ADDRESS FROM DHCP AND WON'T LET ME LOG IN. [...]
"it"? With my weak psychic powers, I have approximately no idea what
"log in on the work computer" actually means. A quick Web search for a
spelling-corrected version of your error message ("ENET0", not "ENETO")
suggests that you might be using some kind of VPN, about which I know
nothing. Someone at "work" might know for whose IP address it's
looking, and why it doesn't find it.
> [...] Everthing on my personal side works great now. [...]
Which suggests that, whatever the problem is, your (unspecified) "a
new onr" might not be the culprit.
- wyogalDec 30, 2020Aspirant
Sorry, I am not very literate on computer info & I am very general. "It" is my Working from home computer. I have another computer-- personal hooked up also and it working fine. The item that is new is the Netgear.
Thank you for trying to help me.
