Rootboy
Dec 17, 2020Tutor
Getting 35 Mbps *upload* with xfinity & C7000v2
I have the DOCSIS 3.0 Nighthawk-AC1900 wifi cable modem router product C7000v2, firmware 1.03.01, and the gigabit plan from xfinity which features an upload speed up to 35 Mbps and 1000 down. How...
- Dec 18, 2020
Just bringing closure to this thread, I had to buy a DOCSIS 3.1 device, I chose the flagship CAX80, to realize the 35 Mbps upload speed with xfinity. It worked fine upon the provisioning, getting close to 1Gbps down and 40 Mbps up.
Just side commentary, the QuickStart instructions for the CAX80 say to use the nighthawk iOS app; I traditionally configure manually, yet thought I'd give the app a try... In this first experience with it, my suggestion would be to RUN AWAY!!! What a POS!!! The app walk-thru didn't seem to be connecting to the CAX80, even multiple tries using the QR Code, and once it finally did connect and I went thru several steps, it ultmately failed. And the walk-thru sequence didn't make much sense to me either. Even within the manual config in a web browser, a couple of steps in, a page with essentially no navigation, no Yes or Cancel, Back or Continue buttons, jumps in the way! YMMV :-(
Thanks for the help and consultation!
Rootboy
Dec 17, 2020Tutor
Thanks for that scoop as well.
Rootboy
Dec 17, 2020Tutor
next log pic
- RootboyDec 17, 2020Tutor
oops!
next...
- plemansDec 17, 2020Guru - Experienced User
Has the isp checked the line? you have a lot of t3 errors and sync issues. Plus the cmts sent a reboot signal yesterday. Thats the docsdevresetnow
If they haven't, I'd have them check the line.
Your power levels looked fine but the logs show issues
