Aephir
Dec 15, 2020Aspirant
Getting an error in R7000 "The IP address conflicts with the WAN IP subnet".
When I try to make (aaply) changes in DHCP, I get the following error when pressing "apply": The IP address conflicts with the WAN IP subnet. Please eneter a different IP address Of (potentia...
michaelkenward
Dec 26, 2020Guru - Experienced User
Aephir wrote:
- I have a Nighthawk X4 AC2200 connected via ethernet, set up as AC.
Even if you mean "AP" AC2200 isn't a Netgear device that I can find.
Many devices come with an AC2200 tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
It looks like the only AC2200 routers are Orbi devices.
Aephir
Dec 26, 2020Aspirant
Here you go:
https://www.netgear.com/home/wifi/range-extenders/ex7300
I guess it's also called ex7300, but listed as "AC2200 WiFi Mesh Extender (EX7300) Nighthawk® X4"
michaelkenward wrote:Even if you mean "AP" AC2200 isn't a Netgear device that I can find.
- michaelkenwardDec 27, 2020Guru - Experienced User
Aephir wrote:
Here you go:
In that case, if that really is what you are trying to fix, this isn't the best place to look for previous conversations about that device that might be useful
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. Your device is a wifi extender.
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for the EX7300. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR CommunitiesRouters and extenders are very different animals.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
