dbarker85
Aug 08, 2021Star
Getting DNS_PROBE_POSSIBLE error on R8000
In about the last month and a half, I have started noticing two things: * pings spike every 5 minutes, from about 8-9ms, to over 1000ms, for 5-10 seconds (this messes up Remote Desktop) * DNS_PR...
Carcathian
Jan 04, 2022Aspirant
I too am having this issue and it's frustrating to do anything when you have to refresh your web pages or applications most of the time, Especially now that I and many others work remote from home. I know a lot more people must be getting this issue but won't know the root of the issue since everything online points people to just release, refresh and renew DNS. The common user usually does not know toubleshooting with process of elimination to pinpoint it to the router.
Is there anyone from the customer support or dev team seeing this?
I just hate having to get a new router and to review Netgear routers badly becasue of something simple as a firmware issue.
- FURRYe38Jan 04, 2022Guru - Experienced User
"I rolled back from 76 to 68 and the problems went away."
- dbarker85Jan 04, 2022Star
I agree, it seems not okay that this is still an issue after all this time. FreshTomato is working well for me, but it's not trivial and the product should work without having to do that. I will caution that FreshTomato once rebooted and reverted back to factory settings. Should you go that route, back up your config, particularly if you use QOS. Which, btw, QOS is awesome, but takes some tweaking. Very useful.
Users are encouraged to contact NG support and let them know what here seeing. https://my.netgear.com/support/contact.aspx
Good Luck.
- Bob_KJan 04, 2022Tutor
I've seen devs forward this problem in other threads, but users are welcome to make additional requests through Netgear customer support.
Edit: FURRYe38 beat me to it.
- SmallTraderJan 04, 2022Apprentice
The DNS problem with R8000 is known over 6 months ago starting with firmware R8000-V1.0.4.74_10.1.80 . In fact there are many models (eg. R6*** and R7*** models) affected with the DNS problems. There is a zillion threads on this forum regarding the DNS problems. Many users including myself have reported the problem to Netgear to no avail. Netgear did not even have the courtesy of formally acknowledging the provblem on their web site and leave many users with automatic update in a bad spot.
The biggest irony is update and you are screwed. If you don't update you are potentially left with security vulnerabilities.I don't think Netgear cares about support at all. All I am saying is don't hold your breath with Netgear. If you can, time to move on with another brand. It is a shame that Netgear used to be a great company with good support but probably lost that some years ago.
