dbarker85
Aug 08, 2021Star
Getting DNS_PROBE_POSSIBLE error on R8000
In about the last month and a half, I have started noticing two things: * pings spike every 5 minutes, from about 8-9ms, to over 1000ms, for 5-10 seconds (this messes up Remote Desktop) * DNS_PR...
vinada
Apr 01, 2022Aspirant
Finally a new R8000 firmware available.
https://kb.netgear.com/000064738/R8000-Firmware-Version-1-0-4-84
Anyone tried yet?
- vinadaApr 01, 2022Aspirant
Ok i tested. DNS problem still there with this latest firmware. Hopeless...
- dbarker85Apr 01, 2022Star
I don't get things like this. Maybe they don't want to maintain it because they think people will give up and buy a newer router FROM THEM? I think more likely people will move on to another brand. And you know they CAN fix it, since previous versions of the firmware didn't have the problem.
Very odd to me. Its great hardware--FreshTomato firmware proves that. Why have crap firmware, not fix it, and tarnish your reputation? Strange.
- FURRYe38Apr 01, 2022Guru - Experienced User
Did you factory reset and setup from scratch after the new FW was loaded?
- robjakApr 01, 2022Luminary
Netgear Engineering was able to fix the DNS issue in Sept 2021. They just have not released it yet.
