dbarker85
Aug 08, 2021Star
Getting DNS_PROBE_POSSIBLE error on R8000
In about the last month and a half, I have started noticing two things: * pings spike every 5 minutes, from about 8-9ms, to over 1000ms, for 5-10 seconds (this messes up Remote Desktop) * DNS_PR...
vinada
Apr 01, 2022Aspirant
Ok i tested. DNS problem still there with this latest firmware. Hopeless...
Apr 01, 2022Guru - Experienced User
Did you factory reset and setup from scratch after the new FW was loaded?
- robjakApr 01, 2022Luminary
Netgear Engineering was able to fix the DNS issue in Sept 2021. They just have not released it yet.
- SmallTraderApr 01, 2022Apprentice
The DNS problem was reported by multiple people across multiple models of Netgear routers nearly a year ago. Netgear knew about the problem and yet consistently release firmware versions which did not fix the problem.
Netgear has demonstrated a real contempt for its customers. My advice to all Netgear customers is they should consider carefully do you want to stick with an organisation which doesn't care about its products and customers. For me, I have already given up and moved on from Netgear. Caveat Emptor !
- Fatman305Apr 01, 2022Tutor
I always do, as I, too, like to: 1. reduce chance of easily solvable issues (due to engineers not correctly migrating old settings - or "future" (possibly unknown) settings, in the case of downgrading firmware). 2. log how the default settings change, since my baseline for future configs is based on default + my very own (few) changes (rather than log endless default settings - makes pinpoining "new" issues much easier too - as they're likely due to one of those few changes I've made). Latest firmware is still broken...
vinada wrote:Ok i tested. DNS problem still there with this latest firmware. Hopeless...
- FURRYe38Apr 01, 2022Guru - Experienced User
Ok thanks for letting us know.
Go back to v.62 or v.68 as I believe these two version don't experience these issues with DNS.
Thanks, I did downgrade. Issue was resolved for me with V1.0.4.68_10.1.75
FURRYe38 wrote:Ok thanks for letting us know.
