p0se1d0n
Sep 19, 2019Guide
Getting IPV6 to Un-Filter ICMP???
R7800 (latest .63 firmware) Hello. Is there a way to un-filter ICMP messages using IPV6 on the R7800 router? I’ve tried BOTH stock firmware and Voxels firmware to no avail. My previous Asus rout...
- Sep 28, 2019A Netgear engineer replied to my inquiry about this issue with the following:
As per our router specification "An implementation MUST NOT send out the ICMPv6 echo reply on the router’s WAN interface if the “Respond to Ping on Internet Port” option is not enabled” for security reasons. So that means in order to allow this user must enable respond to ping on internet port. R7800 should have an option for IPv6 ping on the debug page. If you go to debug page you should see an option called “Allow external IPv6 hosts ping internal IPv6 hosts” and user need to enable this if he wants external IPv6 address to ping internal ones."
To access the debug page, just type this address on your browser 192.168.1.1/debug.htm or routerlogin.net/debug.htm and login using the router's credentials. Scroll down to the bottom and look for Allow external IPv6 hosts ping internal IPv6 hosts and enable it.
Should I try this or is this a security concern? Not sure what to make of this. Thanks
microchip8
Sep 20, 2019Master
On my R7800 with .63 firmware, NETGEAR has only opened ICMPv6 ping requests so when you go testing your IPv6, it fools the test sites that you have fully open ICMPv6. This is not the case as I can see with "ip6tables -vL" when I log in with telnet that only ICMPv6 ping is passed through. The rest, mandatory ICMPv6 settings are filtered out.
So in short, at least on the R7800, you're fooled in beleiving that they finally stopped filtering ICMPv6. I've created a thread(1) at the Ideas forum but it seems NG will not change its mind about ICMPv6
NETGEAR is the only commercial router manufacturer that does this sh*t. All others correctly pass all of the required ICMPv6
Also, keep in mind that Windows 10 by default filters out ICMPv6 too. You have to open it in your Windows 10 firewall. I'm on Linux so have full controll on what I filter and what not. The same can be done on Windows
(1) https://community.netgear.com/t5/Idea-Exchange-For-Home/Stop-blocking-ICMPv6/idi-p/1126371
James721
Sep 20, 2019Luminary
Thats interesting here on .63 ICMPv6 is still very much blocked. I have never found one NG firmware were this was not blocked.
- microchip8Sep 20, 2019Master
Here's what I'm getting on tests.
IPv6 test: https://owncloud.teambelgium.net/index.php/s/3qQ4cBf0jwDvbDV
.63 firmware option: https://owncloud.teambelgium.net/index.php/s/SZU8EXD4hHOqlfW
Here's a guide for Windows to allow ICMPv6 (scroll to the middle): https://www.howtogeek.com/howto/windows-vista/allow-pings-icmp-echo-request-through-your-windows-vista-firewall/
- p0se1d0nSep 28, 2019GuideA Netgear engineer replied to my inquiry about this issue with the following:
Should I try this or is this a security concern? Not sure what to make of this. Thanks- _Bender_Jan 31, 2020Tutor
Sweet! Works as it should now :)
