antiguy1994's avatar
antiguy1994
Getting Unidentified Network with Nighthawk R7300 DST using the DST Adaptor with Ethernet
I am using the Nighthawk R7300 Router with the DST Adaptor using an Ethernet Cable and I am constantly getting Unidentified   Network when It idenfies when I turn it on. I been using it for about a m...
  • antiguy1994's avatar
    antiguy1994
    Aug 11, 2018
    Update
    I think I found the solution at the very least it was able to correctly get a ip address and work like it was before. I was restarting the router with the gui before and this time I when I tried restarting the modem I manually hit the off on switch on the router and tried using the adapter again and it worked.
