jrl95608
Jun 30, 2021Follower
Giving the same name to extender network
If I give my extended network the same name as my router network, how do I force a device to connect to the extended network? How do I know devices that are connected to the extended network rather than the existing router network?
1 Reply
If you're using a mesh extender or just setting the ssid's the same, then you're devices are doing the roaming.
If you're wanting them seperate, then name the ssid's different.
