Jbenhart
Nov 04, 2019Guide
Google Assistant says Sorry Netgear no longer available.
Hello, I had my Google home working just fine with my Netgear nighthawk but now when I request anything from Google, it tells me "Sorry, Netgear is no longer available." I tried re-adding the Ne...
- Nov 07, 2019
We are aware of the issues with google Home and this should now be fixed please let me know if you still can not connect your google devices.
DarrenM
IrvSp
Nov 04, 2019Master
Not enought info?
I assume NETGEAR is the Wifi SSID? Google home has no Wifi signal? Is that it?
What DEBUG have you done? Does Google home even see any SSID's?
What is the ROUTER and what are the colors of the LED's?
Do you have ANY devices connected to NETGEAR?
- JbenhartNov 04, 2019GuideNetgear is the brand of the router? And also the trigger phrase to control the router with google home. You're suppose to say, "ask Netgear to reboot router." etc., but it just errors. Google home and nighthawk are working fine. Both Google home and nighthawk are connected. 20+ items connected to the router, all fine. I've tried to reconnect the voice functionality to Google home and it just says Netgear is not available.
- ascernasNov 04, 2019GuideNot sure if this helps but I am new on Netgear and recently I tried to look for it on the list from Google Home and I don’t longer see them, so I may guess they removed the integration.
I do also have Amazon Alexa and they still have Netgear integration.
