Jbenhart
Nov 04, 2019Guide
Google Assistant says Sorry Netgear no longer available.
Hello, I had my Google home working just fine with my Netgear nighthawk but now when I request anything from Google, it tells me "Sorry, Netgear is no longer available." I tried re-adding the Ne...
- Nov 07, 2019
We are aware of the issues with google Home and this should now be fixed please let me know if you still can not connect your google devices.
DarrenM
DarrenM
Nov 07, 2019Sr. NETGEAR Moderator
DarrenM
- randelldNov 19, 2019Aspirant
I am also trying to add my netgear D7800 router to google assistant but netgear does not appear on the list.
- JbenhartNov 19, 2019GuideYou can also use the voice trigger to connect your router to Google. I believe you tell Google assistant to "talk to Netgear." If not, give it a Google. You don't have to add it manually though. You can use your Google assistant and it'll walk you through it.
