AllenT4546's avatar
AllenT4546
Follower
Sep 14, 2020
grayed out settings
When I go into my router settings I find a lot of them grayed out. I cannot go into LAN settings or port forwarding and a lot of other settings. Why is this? Am I missing something?
  • > Model: WNDR3700v4|N600 Wireless Dual Band Gigabit Router
       Is that accurate?  Firmware version?  Connected to what?
       Is your router configured as a wireless access point?
          https://kb.netgear.com/26765
       On some models (firmware versions), that status is mentioned
    prominently (in yellow?) near the model number on its management web
    site pages.  Otherwise, a "router" LAN IP address which does _not_ end
    in ".1" might be a hint.
1 Reply
