StephLader
Dec 14, 2020Aspirant
GS105v5 causes pixelated areas on PVR
Hello there, I purchased this device about 3 months ago and everything seemed to operate just great. In the last 10 days the device has been causing errors in the video stream. The router is located...
StephLader
Dec 15, 2020Aspirant
Thank you for the help on this one! I had the internet provider replace my router yesterday with a new one and the problem persists with the same symptoms. Yes, I can confirm that if I take the switch out of the context the PVR runs without problems.
microchip8
Dec 15, 2020Master
Then your switch is faulty. If it's still under warrenty, you may contact NETGEAR for an exchange. If they do difficult about it, might buy a new switch instead
- StephLaderDec 15, 2020AspirantThanks again! I will give it a try as it is only 3 months old ... I’m based in Calgary, Canada so it will be interesting to see how much will the shipping cost me ... I’m not happy about this at all... what a waste of money...
- labattDec 15, 2020Mentor
Looking at what these sell for on Amazon, I would say it is bin time and move on. Not sure, with my less then stellar experience with Netgear that it would be another Netgear.
