Paolo00's avatar
Paolo00
gs108v4 all but one pc doesn't connect to the LAN
Hi, I'm Paolo and I'm new here.
I got a brand new gs108v4 unmanaged switch.
We're 4 of us, each one with his own laptop.
I have an ISP modem/router wifi with 4 lan port, one of which is also wan.
The gs108 is connected to a lan port of the modem/router.
I have an access point connected to the gs108. It is an old ISP modem/router wifi, with dhcp disabled and wifi repeater enabled, with 4 lan port, one of which is also wan.
Each room of the house has a lan plug.
All the laptops work fine in wifi.
All laptops but one work fine with the eth cable, connected either to the gs108 or the modem/router switch or the access point switch.
The one that does't link via cable, doesn't work ONLY when connected to the gs108v4, or to a port of the access point. It works fine, at 1gb, full duplex, if connected to the modem/router port.
All the ports of the GS108 are working well; I tested it with different PCs and cables.
I tried:
- all the combinations of wan/lan connections with different cables and pc;
- booting different kernel;
- booting with a live cd;
but the situation is still the same.
In the terminal, the eth interface is reported 'down' and led of gs108 are off only when the funny laptop is connected to gs108.
Do you have any suggestions? thank you very much
when connected to modem router:
[denver@denver-asus ~]$ sudo inxi -zin
Network:
  Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter driver: ath9k
  IF: wls1 state: down mac: <filter>
  Device-2: JMicron JMC250 PCI Express Gigabit Ethernet driver: jme
  IF: ens5f5 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IP v4: <filter> type: dynamic noprefixroute scope: global
  IP v6: <filter> type: dynamic mngtmpaddr noprefixroute scope: global
  IP v6: <filter> type: dynamic noprefixroute scope: global
  IP v6: <filter> type: noprefixroute scope: link
  WAN IP: <filter>
when connected to gs108
Network:
  IF: ens5f5 state: down mac: <filter>
  WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
  • michaelkenward's avatar
    michaelkenward
    The WAN port is usually there to connect the router to the Internet through a modem or something else. It is not always (usually?) available for LAN connections.
    But without knowing what this router is that is anybody's guess.
    That is not the best way to reuse a router as an access point. But again, without knowing what this router is that is another guess.
    As the only piece of Netgear equipment here seems to be the switch, asking about that in this section, which is for routers, isn't the best approach.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Switches - NETGEAR Communities
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
    • Paolo00's avatar
      Paolo00
      hi Machael, thanks a lot, right now I realized I wasn't in the unmanaged switch sub forum...where I supposed to be, sorry
        michaelkenward
        No problem. No one can blame you for getting lost in Netgear's labyrinth.
