JimH1959
Dec 15, 2020Aspirant
GS108V4 unmanage switch blocking ports 80& 443
I have an Arlo camera system that was working fine when connected to our WiFi router, but switched locations and it is now connected to the unmanaged ethernet switch. It stopped connecting, and they ...
schumaku
Dec 15, 2020Guru - Experienced User
Is there any NAT and/or WiFi router in this fiber Internet installation? If not, one system might work on the single public iP address you get from the ISP (intended for the WAN/Internet interface of a router) e.g. on your ONT, but your Orbi system does not have neither a private LAN IP nor a public address where it can reach the Internet - so it tells you the ports are bocked.
- microchip8Dec 15, 2020Master
Unmanaged switches can't block ports. Your issue is somewhere further in your setup
- schumakuDec 15, 2020Guru - Experienced User
microchip8 wrote:Unmanaged switches can't block ports. Your issue is somewhere further in your setup
This is correct - however Arlo does show this misleading message if it can't reach the cloud over 80/TCP and/or 443/TCP for whatever reason.
- JimH1959Dec 15, 2020Aspirant
I originally had the WiFi router connected first and the unmanaged switch downstream. I recently swapped the locations in order to provide more ethernet connections where the WiFi router was connected. I'm sure this is the source of the problem, I will re-locate the devices and confirm. Then, I'll probably get another unmanaged switch to provide the quantity of ethernet connections I need. thank you for the responses.
