Greyman65
Jun 25, 2021Follower
GS116 direct replacement
Which model will Directly replace my GS116UKv2? Is the GS116E the same?
Jun 25, 2021Guru - Experienced User
The GS116 is just an unmanaged 16 port switch.
the GS116e is a ProSafe plus version that has additional configuration options.
If you're just looking for an unmanged switch, there's plenty of 16 port versions out there.
