junyan2000
May 20, 2021Tutor
GS305v3 not getting Gigabit speed
I cannot get GS305v3 to connect at Gigabit speed, even with a Netgear router (R7000). Is there a solution? The cable is a 75 foot cat6e cable. GS305v3 will stay on 1000M for a little bit, then th...
junyan2000
May 20, 2021Tutor
The problem is with the GS305v3. In fact, the same switch can get 1000M when connected to my other router, a R6250, with the same cable.
I had nothing but trouble with this piece of crap. The R6250 seems to be the only device it will connect at Gigabit speed. I can't believe Netgear is even selling it.
Has anyone tried 12V power adapter with GS305v3? I know it takes 5V only, but GS308 uses 12V, and it is hard to imagine that GS305 and GS308 use different chipsets,
antinode
May 20, 2021Guru
Huh? At least one of us is confused.
> [...] it is hard to imagine that GS305 and GS308 use different
> chipsets,
The question is the power-supply circuitry, not the "chipsets". You
don't need to "imagine" anything, just read the Product Data Sheet.
(Visit http://netgear.com/support , put in your model number, and look
for Documentation.) Or look at the label.
- junyan2000May 21, 2021Tutor
The GS305v3 gets gigabit speed only when it is connected to Netgear R6250, but not when it is connected to Netgear R7000, or any other routers/switches that I can find.
So there is no way to make the GS305v3 - a gigabit switch - to connect reliably at gigabit speed, even with another Netgear product. To this switch, gigabit speed (with R6250) is more an exception than the norm. Is there a way to request a refund?
- michaelkenwardMay 21, 2021Guru - Experienced User
The GS305v3 is an inexpensive bog standard £$€15 "Gigabit Ethernet Unmanaged Switch". There's not much that it does, or that you can do to it. If you are having problems, I would look elsewhere on your network.The things it talks to rather than the switch itself.
But if you do want to troubleshoot the GS305v3 this is not the best place.
You might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for that device. That's probably here:
Switches - NETGEAR Communities
If this were the case, then we would have heard about it by now. I see no hint of this as a generic problem over in the "switch" section.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.- antinodeMay 21, 2021Guru
> routers/switches that I can find.Too vague a description of your testing for me to conclude anything.
A defective GS305v3 is unlikely, but possible. A fundamental design
defect in a product with the volume of a GS305v3 is practically
impossible.> [...] Is there a way to request a refund?
Ask whoever sold it to you? Exploit the warranty?
> [...] If you are having problems, I would look elsewhere on your
> network. [...]Because a defective GS305v3 is an impossibility?
