amilbourn
Nov 23, 2020Aspirant
GS308 Problem with HP Laser Printer
Dear all, I have the switch with a PC and an HP laser printer connected to it. The switch is connected to an EERO mesh wifi network.The reason forthe switch is that the EERo has only one spare ether...
amilbourn
Any ideas how I change the settings so it works please?
antinode
Nov 23, 2020Guru
There are no settings to change on an "unmanaged switch", and the
non-psychics in your audience know very little about the rest of your
situation.
> [...] the PC will not print to the printer [...]
"not" is not a very detailed description of what happens. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
What are the IP addresses of all these gizmos? What, exactly, is
connected to what, exactly?
> [...] the PC connected to the switch will print to the printer if it
> is connected directly to the printer. [...]
What, exactly, does "connected directly to the printer" mean to you?
USB? If you've installed the printer on that PC with a (private) USB
connection, and then you disconnect the USB cable, and connect the
printer to the network, then I would not expect that PC to figure out
where the printer went. If you haven't told Windows on that PC about
the network-connected printer, then you might want to try that.
